Database Maintenance Completed
We completed a overhaul of the backend code for the database and collection/trade system. This will ensure a higher level of security moving forward and better compatibility for the future. No features were added during this upgrade. If you experience any issues, please report them here: https://www.diecastmodelaircraft.com...ave-any-issues
See more
See less
1/400 scale Kona International Airport Build
  • 1/400 scale Kona International Airport Build
    Hello Everyone,
    I started this project about a month ago and wanted to start a build thread for everyone to follow if they are interested. This airport is based in Kailua-Kona, Hawaii; also known as Kona International Airport (KOA). I started with a 20"x30" foam core poster board. I cut the poster board in half to create two 20"x15" boards and laid them side by side. I designed the hut like buildings using Sketchup and had them 3d printed on Shapeways. Terminals 1 and 2 will have the buildings laid out in the exact same way. I also grabbed some z scale palm trees from a local hobby shop that carries them, I will need a lot more. I drew the taxi line with a yellow paint pen using google maps as a template to get a start. I also used many of my models to get the spacing correct.
    This is still very much a work in progress. I still have lots to paint and build till it is completed.
    Hopefully will have another update soon.
    Looking good Maurice. The stairs are interesting - do they use unusual stairs like those in Hawaii?
    • Maurice Bollhorn
      Maurice Bollhorn commented
      Thank you. At Kona they use a ramp system rather than stairs or gates, from the research I have done. It is adjustable so it works for almost all airplanes.
    Very nice, I do like the livery.
